By kd_kimball - 4 Years Ago
Can anyone point me in the right direction? I have an old CrazyTalk file that I created back in 2006. I would like to open this file so that I can extract/record the audio in that file which was a recording of my daughter originally that I would like to preserve. When I try to open the file that was created it says that it needs to install CrazyTalk4 Player, which I cannot find anywhere. Is there any hope of being able to open this old file? Kelley Kimball kd_kimball@msn.com
By Peter (RL) - 4 Years Ago
Hi Kelley
Unfortunately CrazyTalk 4 has long been discontinued and the CrazyTalk Web Player is no longer compatible or supported.
Do you have the actual CrazyTalk 4 project file? If so you could send that to me by private message and I can probably open it and generate a video for you. However, if you don't have the CT4 project file and only the exe file shown in your post, then it may not be possible to gain access to the audio. Again, if you would like to send me a link to download the exe file by private message I'll take a look for you to see.
Peter, The forum won't allow me to PM you. Says something about your PM space being full or at capacity.
Apologies my mailbox fills up fast. It should be ok now. Please can you try again.
Hi Kelley
I have sent you a private message with the audio extracted from the .exe file. Please check your forum inbox to find it.
I hope it helps. :)
