Iclone 7.91 Only jerks - Show stopper
https://forum.reallusion.com/Topic483346.aspx
Print Topic | Close Window
By ReiniWien - 5 Years Ago
Hi can anybody please verify, maybe with an RTX2080ti, if he has the same behaviour:
All my scenes we have done in the last year are now playing in REALTIME only with jerks. First we thought it's because of many animations and props, but now we see, there is general something wrong.
IClone doesn't work without jerks anymore. Please see my screencast of the Loft scene
https://drive.google.com/file/d/1WF280nZgL9MOfVpZLeuduqMcDawys8hx/view?usp=sharing
Does anybody have the same troubles? I work now since a year, without problems. I know the things "How to reduce the pay load" while in Realtime.
But now i have no idea. GFx drivers didn't change when the troubles started. Now i updated and same behaviour.
Please if you test with RTX 2080 ti please post me your driver version.
System is good as i told you, i work now since a year with 32 gb and rtx2080, ssd, so no components were changed.
Best regards, Reinhard
By mark - 5 Years Ago
Does the Rendered scene "jerk" as well?
hi mark,
no jerks in rendered scene
By 3Aliens - 5 Years Ago
I have the same System but only 16Gb. This looks very well even in the Preview! Did you try to make resolution smaller in the Preview Options?
Hi 3Aliens, thx, please can you tell me your driver version?
Yes tested with different screensizes, no differences
By charly Rama - 5 Years Ago
There's something eating your memories because I see that you get 15 - 17 FPS with your great config (2080ti , 32Go VRAM , Btw, what CPU ?) , with my poor 2060 , I get fluid 40 FPS at the loft scene.
LAtest Drivers for all. I even have the GAming Software, not the Animationsoftware Driver.
ISSUE IS FIXED NOW by changing setting VERTICAL SYNC in NVIDIA PANEL. setting was, that the application should decide. This was the problem. I changed this to an other value (if i remember right there are also ON OFF but can‘t tell at the moment which one i took. sorry i am over 50 years old ;-)
thank you all for your ideas, best regards ReiniWien
