By il.zhukov - 5 Years Ago
Can I use these files in CrazyTalk8?
and if Yes, how?)
Waiting for your feedback.
By Peter (RL) - 5 Years Ago
Hi...
The content you show are accessories for Character Creator.
CrazyTalk 8 is compatible with content from Character Creator but as CT8 is now quite an old product it is only compatible with characters and content from Character Creator 2. It isn't compatible with content from Character Creator 3 unfortunately.
So the way it would work is you would create your character in CC2, add clothing, hair and accessories as required and then export as an .iAvatar file. Now in CrazyTalk 8 Pipeline you could import the .iAvatar file where you can then save the character, clothing, hair and accessories into your CT8 library for later use.
Please Note: You need to have CrazyTalk 8 Pipeline version to be able to import and export content.
Peter (RL) thank for your answer
Is there a Character Creator for Mac?
Peter (RL) hi! do you know where can i get CC2 packs? And i don't have Windows.
What should i do?
Hello I was killed what is it? what to do?   hm, wtf?
il.zhukov (5/7/2021) Peter (RL) thank for your answer
Unfortunately there isn't a Character Creator for Mac. All versions of Character Creator are Windows only.
Peter (RL) hi! do you know where can i get CC2 packs? And i don't have Windows. What should i do To be able to use Character Creator content packs you will need to have CC2 or CC3 installed and these sadly require Windows.
il.zhukov (5/9/2021)
Hi...
Did you install the latest CrazyTalk 8 trial version from the page below? And did you use the Reallusion Hub to install?
https://www.reallusion.com/crazytalk/download.html
If you didn't, please use the link provided on the page above to make sure you are installing the latest version. This should avoid you getting any errors like the one shown.
Peter (RL) sad, i'll think
