Transparency .MOV scenes and some Pop Video, Music Video
https://forum.reallusion.com/Topic480678.aspx
Print Topic | Close Window
By Animaniac - 5 Years Ago
Hi Folks, here's a video I made for one of my tunes. I used the .MOV transparent footage thing on the scenes with the robot against a starfeild segment, the rapid change in size to the music was done in after effects. This saved me a bit of time, I usually would have done that using green screens.
For the rest of the video I rendered in CA4 with the Pop Video, and imported the images on a flat surface into iClone.
By kylelee - 5 Years Ago
Great I like your animation style.
Do you have any feedback for us or meet some issues?
The only feedback I have at the moment is I couldn't get the transparency in the .MOV within iClone, but used popvideo instead which worked. I thought maybe it is because I'm using windows? Pop video worked fine though, but I initially tried applying the mov as a texture on a flat plane, but as I said, couldn't achieve the transparent background.
OK, I got it,
If you have any suggestions, please have to tell me.
Thank you so much.
