By clonechiklo - 5 Years Ago
The following are You tube links to 4 videos recording the actor dislocation problems I encountered when combining different motion clips as well as when the actor was assigned to a motion path. Video One: IClone 7 actor dislocation with some motion clips having a different motion root or origin https://youtu.be/ELZJWudTPdIVideo Two: IClone 7 actor dislocation when 2 motion clips are being mixed https://youtu.be/C-0y5fcEZn8Video Three : IClone 7 - Correcting actor orientation of a motion clip https://youtu.be/1DNSpywTWlAVideo Four : IClone 7 actor dislocation on Motion Path after receiving 3 motion clips https://youtu.be/1dju9ntsQcUVideo 4 introduced a procedure delivered from IClone Technical support and it is not that easy for starters to discover; Recommended to watch!
By animagic - 5 Years Ago
Did you know that you can embed videos? You also have black text on dark grey, which is hard to read (below are the fixed text and embedded videos).
Video 1: IClone 7 - actor dislocation with some motion clips having a different motion root or origin:
Video 2: IClone 7 - actor dislocation when 2 motion clips are being mixed:
Video 3: IClone 7 - Correcting actor orientation of a motion clip:
Video 4: IClone 7 - actor dislocation on Motion Path after receiving 3 motion clips:
Thanks a lot.
