No Omniverse Assets in Localhost - Result: Error Connection
https://forum.reallusion.com/Topic480458.aspx
Print Topic | Close Window
By TonyDPrime - 5 Years Ago
Is there a known resolution for connection issue to Local Host, or does it just go down from time to time
https://forum.reallusion.com/uploads/images/e1af02b8-6e62-406f-a5d0-d96c.jpg
https://forum.reallusion.com/uploads/images/be8c3c4e-2bb6-41b7-8b20-34f8.jpg
RL - Are you supposed to be able to login with this?
https://forum.reallusion.com/uploads/images/f4d7ce4f-783d-4670-bc02-db96.jpg
RESOLVED - I had to set up the Collaboration Nucleus in order to get this stuff.  I had skipped the step during my initial setup.
By Veneris - 4 Years Ago
How to connect what is the number of the server?
By AESTHETICISMFT - 4 Years Ago
打开NVIDIA Omniverse Launcher程序,在NUCLEUS面板中,设置-添加本地NUCLEUS服务
open
NVIDIA Omniverse Launcher,Click NUCLEUS”page,Setup;“Add local NUCLEUS service”
设置路径;使用默认。
Setup path Use default path
使用NVDIA开发者账号登录,用户名保持一致
Use Nvidia developer account Login to, Username remains the same
登录其账号。good luck~
Login to account good luck~
