By larrygj - 5 Years Ago
I have CC3 3.4.1 installed and working properly, but Omniverse keeps producing the following error message after uninstalling and reinstalling the connector:
Error occurred during installation of REALLUSION CHARACTER CREATOR 3.41: Command failed: "C:\Users\larry\AppData\Local\ov\pkg\reallusion-character-creator-connector-3.41.3\InstallCcConnectorExe\InstallCcConnector.exe"
Any idea for a fix?
By Peter (RL) - 5 Years Ago
Hi...
Have you been able to install the Omniverse Applications like Create, Drive and Cache into that same folder without getting an error?
If you did get the same error with them then there might be a permissions issue accessing that folder.
If that is the case, try opening up the Omniverse Launcher and click on Settings > Settings (top right of the launcher) and try changing the install folders. For example I use the folders below.
