By Crazy guy - 5 Years Ago
Cloth(Tshirt) sent as OBJ in Marvelous Designer and simulation inpoerted as Alembic(abc) in Iclone. Not perfect
By 4u2ges - 5 Years Ago
Nice. Just some tips.
Before exporting FBX or alembic animation out of iClone for MD, make sure to inspect it thoroughly. MD (and probably any other simulation engine) does not like when simulated mesh gets smashed between 2 collision objects. And moreover, when those 2 objects intersect. Make sure hands are at least 1 centimeter away from the body for the entire animation.
Fingers (and specially if lady has long nails) are going through the mesh like a knife through the butter, while cloth is simulated. If I intend sometimes to pull the cloth with fingers/hands during simulation, I would do it manually in MD during simulation (with picker) and then in iClone try to animate hand to follow after alembic import. (does not work for cloth with sleeves). Or, I put special, smooth/solid gloves on a character before exporting from iClone and hide palms altogether. This way there is no fingers/nails penetration occur. Maybe there are ways to tweak collision for hands inside MD (and there probably is), but I am not aware (I am not an MD pro :))
By StyleMarshal - 5 Years Ago
haha , great tip with the gloves ... they look like "High Fashion" π , thx for sharing Mr. G !
I normally cut out the hands , so I've to try your Gloves.
Wow thanks I was Γ lso wondering what to do with hands poking through clothes. What an idea for such glove, will surely try that. Thanks a Ton!!
lol yeah, here they are: https://www.dropbox.com/s/bhzi9y1ueka09mo/MD_GLOVES_BASE.zip?dl=0
I made those for a base female in T-pose. For other characters might need a little smoothing/tweaking in CC. They also automatically hide hands mesh.
Update: Added a pair with no fingers deform as well. Those are just following hands bones.
Super Cool , thank you MR.G π
By 3dtester - 5 Years Ago
Impressive :)
Thanks so much for the file. Will try Γ nd see the difference
No problem and good luck. But remember gloves, or no gloves hands should not penetrate body in any single instance of the animation. If it does, you need to fix it before exporting.
By matenn30 - 5 Years Ago
4u2ges, it's like thick pot gloves. It will be even better if you add a pattern.
4u2gesγγγεγιζθ’γΏγγγͺζγγ§γγζγε
₯γγγγγ£γ¨η΄ ζ΄γγγγͺγγΎγγ
Ha ha, exactly. Straight from the kitchen. I know what you mean. Everything, even utility gloves should be aesthetic :) Leopard skin is good? ;)
ε€§δΈε€«γ§γγθ±ζγγγγ¨ζγγΎγγ okγ§γγθ±ζγγΎγγγγ¨ζγγΎγγ
By animagic - 5 Years Ago
matenn30 (4/15/2021) ε€§δΈε€«γ§γγθ±ζγγγγ¨ζγγΎγγ okγ§γγθ±ζγγΎγγγγ¨ζγγΎγγ
According to Google Translate:
It's okay. I think the floral pattern is also good. It's ok. I think the floral pattern is also good.
