What are the recommendations if I want to do facial motion capture from a video
https://forum.reallusion.com/Topic478719.aspx
Print Topic | Close Window
By cynsegura - 5 Years Ago
I tried long time ago with Many cam and faceware and motionlive
I was asking if there was any update to do this in a better way.
Many thanks
By charly Rama - 5 Years Ago
Hi, as Mike Kelley  said, like him, I have both, and I leaved faceware. For now, the only way for facial mocap is using ARKit blendshapes , faceware doesn't use it, only liveface uses it with iphone or ipad compatible. Forget wifi when you mocap, use only cable (ethernet or USB, simple usb works fine for me)
By Kelleytoons - 5 Years Ago
Since you mentioned Many Cam I wondered if you are also talking about capturing video from outside sources (in other words, not having a live subject in front of your own computer).  Faceware can do this, and I show how to do it using Many Cam.
The good news is that Live Face with the iPhone can do this as well.  Weirdly enough.  I can't even explain it other than to show it in a video I made, but you *CAN* capture using Live Face off a video, if that's what you want to do.  As Charly says, Live Face with an iPhone is the way to go nowadays, so if that particular thing is what you want it can do it as well.
