how to change output size?
https://forum.reallusion.com/Topic476818.aspx
Print Topic | Close Window
By Elyssa - 4 Years Ago
Hello, I want to render an MP4 file 690*690 in Iclone. But I can choose only 688 or 692 for width. If I type 690, it's changed 688 automatically.
If anyone knows the solution, please help!
Thank you!!
https://forum.reallusion.com/uploads/images/47cf2638-61c5-4dc9-a51f-6f23.png
By mark - 4 Years Ago
Same here. You have possibly discovered a strange little bug with iClone and an .mp4 ;)
Thank you for the reply.
If I couldn't find the solution soon, I'd better post this issue on Feedback Tracker.
By animagic - 4 Years Ago
Some codecs require a multiple of 4 for the render size. If iClone uses Microsoft MediaWriter then this is indeed the case:
MP4 videos created using the MediaWriter libraries must have a width which is a multiple of 4 and a height which is an even number. If the width is not a multiple of 4 the video will be automatically trimmed by removing pixels from the left and right to make the width a multiple of 4. If the height is not an even number the bottom row of pixels will be discarded.
Since 690/4=172.5, the size would indeed be trimmed to 688. So this is a limitation outside of RL's control.
Oh, I got it. Thank you so much!
