By techmom - 5 Years Ago
Hi guys! I'm brand new at animation, so forgive my noob question. Inserting the snail and applying the snail walk to him and that works. But if I drag another snail walk to him, he starts at the beginning position again. I have tried positioning him and setting a keyframe, but he always goes back to his original position. Any ideas? Thanks in advance for your help.
By jlittle - 5 Years Ago
Typically a motion will be broken down into 3 parts: Start (S), Loop (L), and End (E). As an example: For a motion Walk, there should be 3 motion parts available named Walk S, Walk L, and Walk E. You would string the motions together (in the expected order) for the desired length: Walk S + Walk L + Walk L + Walk L + Walk E.
If your motion does not have the 3 parts then you will need to "blend" the 2 motions together so that the transition from the end of the first motion blends into the beginning of the second motion. A link to blending motions is HERE.
Hope that helps.
Jeff
By vepop - 5 Years Ago
In the Timeline, click the Motion tab. Right click the 2nd motion and choose Align>Bone_1.
Thanks Jeff!
Thank you. The bone alignment worked perfectly!
