By OperantK9 - 5 Years Ago
So, I'm trying to create a custom soccer filed scene. I've created a file that I was going to use for the grass (2 shades of green in horizontal segments) Now, my thought process was: I'll upload the file in CA4, switch to a 3d space and rotate the image on its X axis to create the effect that I'm looking for. However, the it would appear the only rotation is on the Y axis. Basically you can't rotate an image to make it "lie down" you can only rotate items like a tire/clock etc? Am I missing something here? Help please
By Peter (RL) - 5 Years Ago
Hi...
3D View allows you to change depth on the Z -Axis. If you wish to rotate an object you can do this in the standard 2D View and then adjust the depth of the object in 3D View.
By shantybaba - 5 Years Ago
What you want is what I want. Not available in CTA4 Try Moho or After Effects. Or maybe someone here might listen and say... next version?
