Free Bra Cleavage Enhancer Opacity Map
https://forum.reallusion.com/Topic472357.aspx
Print Topic | Close Window
By Data Juggler - 5 Years Ago
I have a character dressed in a bra and panties, and noticed the bra was covering too much of the breast.
The bras do not come with an opacity map, so I created one from the UV map.
I then edited the Opacity map to show a little more cleavage.
You can download the bra opacity image here:
https://github.com/DataJuggler/Textures
Here is the file:
https://forum.reallusion.com/uploads/images/5f0e9006-0170-4c79-9831-36d1.png
And here is a short video demonstrating the texture:
Let me know if anyone finds it useful, and if you think panties need the same thing (less material).
Thanks,
Corby / Data Juggler
By Amper Sand - 5 Years Ago
Hahaha, "way too much material for a bra" :laugh:
Thanks!
By 4u2ges - 5 Years Ago
Long while ago I used a slightly more radical/provocative approach to reduce a default bra *weight* :):P:hehe::w00t:
Default Bra  .iMtl
https://forum.reallusion.com/uploads/images/962ee0db-ba6b-4c5b-8ca7-c62c.jpg
I4U2Ges: I thought of you this morning and increased my characters breast size.
Not enough for your type, but a little more than I might have normally.
By toystorylab - 5 Years Ago
Quick Mix of both...
https://forum.reallusion.com/uploads/images/54612866-9247-4579-aad5-8ff0.png
Thanx guys ;)
How do you create the semi-transparent mesh?
By wires - 5 Years Ago
Data Juggler (2/12/2021)
It's done by applying shades of grey (gray) to areas the opacity map that you wish to be transparent.
I will count that as what I learned today.
I knew black was hidden and white was visible, I should have guessed that.
Thank you.
