3DXchange - iClone Hand Issues
https://forum.reallusion.com/Topic471497.aspx
Print Topic | Close Window
By abhilashswe - 5 Years Ago
I am importing DAZ Genesis 8 character into 3DXchange 7.7 as well as importing into iClone 7 through 3DXchange. The hand seems to be out of sorts in both the programs. We are running out of time. Any help is appreciated.
https://forum.reallusion.com/uploads/images/79a46994-8a1a-4b5b-937e-f54b.png
https://forum.reallusion.com/uploads/images/eeef7dd7-11b2-4944-aca4-e29a.png
PC Specs:
1. AMD Ryzen Threadripper 3970X Processor - 32 Cores. 64 Threads.
2. ASUS TRX40 Motherboard
3. 256 GB RAM
4. ASUS Nvidia GEFORCE RTX 3090 Graphics Card with Hybrid 24 GB + 128 GB VRAM
5. Windows 10
6. 3DXchange 7.7
7. iClone 7.83
By Peter (RL) - 5 Years Ago
Was the character correctly identified as a G8 character in 3DXchange 7 when you imported it?
Also can you let us know the name of the character if it was purchased from the Daz3D or Renderosity stores? Thanks.
Yes I have purchased the following items from DAZ Shop.
https://www.daz3d.com/marnie-hd-for-genesis-8-female
https://www.daz3d.com/linda-ponytail-hair-for-genesis-3-and-8-female-s
Please apply the hair and check.
I tried with the Marnie character and it imported fine for me in both 3DXchange 7 Pipeline and iClone 7 without the hand issues. I didn't export from Daz Studio with hair so try that to see if it makes a difference. You can also see my export settings below. Make sure to choose FBX Binary 2012 in case you were using a different version.
https://forum.reallusion.com/uploads/images/14a187c5-d35b-4a33-a4f3-c282.jpg
Just to add, do make sure you are using the latest build of 3DXchange 7 which is 7.7.4310.1. You can check this my going to Help > About iClone 3DXchange 7.
I also noticed that your character in 3DXchange 7 is in an A-Pose. If correctly identified as a G8 character it should be in a T-Pose like below.
https://forum.reallusion.com/uploads/images/165c48de-5711-42ac-94d0-3348.jpg
Yes I am using the said version of 3DXchange.
Here is the screenshot while importing the FBX version 2011.
https://forum.reallusion.com/uploads/images/e1bc1bb4-2325-4119-b9c6-a46a.png
Please apply the hair and import into 3DXchange. It completely go out of sorts.
https://forum.reallusion.com/uploads/images/c68899f4-14fb-44b7-b8dc-f113.png
Without hair I am getting the T-Pose.
https://forum.reallusion.com/uploads/images/4a43d125-2c48-4efc-877f-9646.png
I don't have that particular hair. Try exporting from Daz Studio without the hair attached to the character. You can then export the hair separately and apply it to your character in iClone.
