NEW! Debris Generator Plug-in
https://forum.reallusion.com/Topic471274.aspx
Print Topic | Close Window
By gordryd - 5 Years Ago
Just released "Debris Generator", a plug-in to quickly clone and scatter items (Props) randomly around your scene.  You select the number of clones and adjust ranges for Movement, Rotation, & Scale for the clones, as well any Color Variations. Cloned props (with physics applied) can also be 'dropped' via gravity onto physics-enabled objects (infinite plane, terrain, etc.) for more natural dispersal.  More info here:
https://marketplace.reallusion.com/debris-generator
https://forum.reallusion.com/uploads/images/b54e72c4-a51d-4389-aab4-cd4b.jpg
By Rampa - 5 Years Ago
Cool! :)
By charly Rama - 5 Years Ago
Waoh, it's great Gordryd, I'll certainly buy it. Very good work
By wires - 5 Years Ago
I notice that the plugin requires iClone 7.9!!! Do you know just when this version will be available? :Whistling:
By Angel Alonso - 5 Years Ago
Looks good!
but maybe there should be some animation video of this, don't you think?
good question  wires
By Podman1000 - 5 Years Ago
Thank you....looks like a very useful plug-in.  I sure wish we could do this with SpeedTrees.....in the vary color feature mainly.
All, thanks for the input.
@wires -- This was just brain freeze.  When I entered the info into the Marketplace form, 7.9 was the default choice.  Unfortunately, I am waiting for 7.9 like the rest of us.  Also, I assume it works on previous Python-enabled versions of iClone, but I don't have those down-revs installed to check, so I played it safe and chose the latest (well, later than the latest)...
@ ATOOM -- I will try to add a "tutorial" (probably using physics w/terrain) when I have some more time.
Hi,
I just added a Debris Generator tutorial here: https://www.youtube.com/watch?v=e5r3Q7pE8SE&list=PL_nBoV24p_ZNmGlW4_qXtlwbRKVXxuo-r&index=3
By thebiz.movies - 5 Years Ago
Very cool little plugin and the tutorial shows the usefulness.  Would be cool if it could read the z value of the terrain to embed within a variable height terrain (similar to the sticks sticking out of the flat one).
thebiz.movies (2/19/2021)
I like that idea a lot. Maybe you can use the snap to terrain value to set that.
It is incredibly fun already too! :)
By naruto.uzumaki - 3 Years Ago
It’s a great thing, it saves a lot of time, though you still have to correct it, because, as a person, a machine cannot yet be creative
