Character size versus scene size; how to resize
https://forum.reallusion.com/Topic471171.aspx
Print Topic | Close Window
By TimothyMasters - 4 Years Ago
Please excuse what must be a dumb newbie question.  I created a character in CC and saved it as iAvatar.  In iClone I put in a scene and then imported my avatar.  But my avatar is a tiny, almost invisible speck in my scene!  It is tremendously undersized for the scene.  Yet I cannot make the character larger, nor can I make the scene smaller.  How do I get my character and scene to conform in size?
By Rampa - 4 Years Ago
You may have added a large scene. With the character selected, press F on your keyboard to zoom in on it.
As a way to compare size, the default grid squares are one meter across. So if your character is about two grid squares high, they are the correct size. So maybe you loaded a giant terrain?
https://forum.reallusion.com/uploads/images/d0d4096d-e7f0-4a6e-a87c-06eb.jpg
https://forum.reallusion.com/uploads/images/007976bd-c8c5-4e16-9316-e3f8.jpg
Press Cntrl-G to show/hide the grid.
But if you do want to change the character scale, it is at the top of the Modify panel.
https://forum.reallusion.com/uploads/images/21464539-986d-4961-947d-2cb2.jpg
Thank you thank you thank you!  I feel stupid that I did not see that scale field.  For any objects I've seen, they have Move, Rotate, and Scale under transform, but the Scale was missing here.  I did not look closely enough; my bad.  Thank you again.
By richard666 - 4 Years Ago
Thank you Rampa.  Ive wanted to find a solution to body scale for years.  It was right in front of my eyes but never saw it.
i bet there are hundreds of people the same. Thank you so much.
By diomkal - 4 Years Ago
Thanks Rampa! Yes exactly for me too. I often even go through CC3.
