How to rremove eyelashes in CC for wrap 3
https://forum.reallusion.com/Topic470790.aspx
Print Topic | Close Window
By eliott.salles - 5 Years Ago
Hi everyone, i am trying to send a charactere from CC into wrap 3, but this charactere as eyelashes and wrap doesnt like separate mesh in the same obj... The wrap process is blocked if i dont removes this eyelashes, and i cant find the way to deletes this eyelashes. I can remove then in my 3D software but if i do that the FBX keys doent fit anymore with my FBX. Where can i remove eyelashes in CC?
Thanks for your help guys !
By Miranda (RL) - 5 Years Ago
Is ZBrush part of your pipeline?
Yes it is.
By lianchiu - 5 Years Ago
1. CC >> GoZ check Split Body Part > Eyelash
2. in Zbrush "DON'T include Eyelash" > others parts Mesh Warp that you want (Any workflow , you can export from Zbrush to different software then Import back to  Zbrush )
3. Body include Eyelash >> GoZ All back to  CC
4. DONE
By mrmejias_570725 - 2 Years Ago
Hi. Thanks for your reply. When exporting fbx to Maya, the eyelashes are included with the body mesh and can't be deleted or the skin weights break. There should be an option to delete the eyelashes inside CC, like the is for tearline and eye occlusion elements.
Thanks
Hi. Thanks for your reply. When exporting fbx to Maya, the eyelashes are included with the body mesh and can't be deleted or the skin weights break. There should be an option to delete the eyelashes inside CC, like there is for tearline and eye occlusion elements.
Thanks
