Use in Unreal Engine 4 for Virtual Reality (Mobile Forward Render)
https://forum.reallusion.com/Topic470567.aspx
Print Topic | Close Window
By calembendell - 5 Years Ago
Hey folks,
I'm running into a few problems using CC3 in Unreal Engine for virtual reality.
If I try to use high quality shaders, I get Riddick eyes, as in the first image below, and translucent clothing.
If I try to use standard shaders, I end up with grey characters, as in the second image below.
I don't believe this has anything to do with my character or the way I'm importing, as if I import in another project using deferred rendering and a desktop target, everything looks good to go.
Has anybody else run into this issue before and have recommendations on solving it?
HQ Shader
HQ Shader under a point light
Standard Shader
By calem.j.bendell - 5 Years Ago
Still no progress on this front.
I'm not a shader programmer, but looks like I'll be trying to fix this myself this weekend.
By lianchiu - 5 Years Ago
FAQ
https://docs.unrealengine.com/en-US/TestingAndOptimization/PerformanceAndProfiling/ForwardRenderer/index.html
https://forum.reallusion.com/uploads/images/5916d1ff-0347-4ec6-9201-d226.png
I was not able to fix the shaders.
Will be hiring someone more experienced with Unreal materials to do it, and will maybe post the results here.
I had thought Character Creator 3 was compatible with virtual reality, but I must have misread.
By david.tully - 5 Years Ago
hi - i replied to your comment on the Reallusion site.
in the offending shader/material - I set the opacity to 2 which made them not see-through.
hope that helps.
images on the other site.
