Opacity doesn't work on character's hair and glasses?!?!?
https://forum.reallusion.com/Topic468542.aspx
Print Topic | Close Window
By sophia.shapira - 4 Years Ago
Okay - I just saw something REALLY wonky happen.
I set a character's opacity to zero -- and most of the character disappeared (as she should) - except her hair and glasses remained perfectly visible.
As much as it would be a drag - I'd be willing to individually adjust the opacity on the hair and glasses separately from doing so on the rest of the character. Only problem is -- I can not find a way to even do THAT.
There is simply no way that I can get my character to make the entrance that I want her to make unless ALL of her, glasses, hair, and all, fade in SIMULTANEOUSLY.
Is there any way for me to get the glasses and hair to fade in?
Thanks,
Sophia
By jlittle - 4 Years Ago
Anything added to a character in Composer Mode from the Props tab is a separate object from the actual character but is included in the characters layers.
Making the character opacity zero only affects the character itself, not the added props.
The added props (i.e. glasses) can be selected and the opacity adjusted independently.
Jeff
