By gingerbear - 6 Years Ago
Hey there, having some issues here. I cant get the FPS to match between Blender and iClone when I export my facial motion capture.
I recorded 1800 frames in iClone using LIVE Face. I then export an FBX of that set for Blender format, set at 24FPS and including the entire range of frames.
Then when I import that FBX into my Blender scene, also set at 24FPS, it only brings in about 720 frames worth, and it seems to be the entire range of motion but at a faster rate so that now it ends at that frame. Do is there a setting I'm missing so i can match that entire range of 1800 frames exported to Blender with the same speed/frame rate as the iclone?
Thanks.
