By shadybearbklyn - 6 Years Ago
For some reason I can't make the Motion LIVE window big enough to show the Smooth Head option at the bottom.
By Peter (RL) - 6 Years Ago
Hi... Which screen resolution are you using? If you are using the recommended 1920 x 1080 then the Motion LIVE window should be full size and all check boxes should be visible.
I do have the screen resolution set to 1920 x 1080. I noticed that this only happens when I'm not using an external monitor from my laptop.
