By guyknigge - 5 Years Ago
Hi, I have Animator 4 Pipeline version. I am creating a talking head. The text to speech works and the head talks, but when I use the voice recorder the character does not speak. I record the voice with the voice recorder, play it back and can hear the voice, select OK, but when played back there is no sound and the character does not speak. I have also imported a wav file but with the same results. I am still new to Animator 4, but I think this was working properly before, when I used it. I am using Animator 4 on a Windows 10 operating system. Thank you for any help!
By DanielC_RL - 5 Years Ago
Hello @guyknigge Because we are unable to reproduce the problem and are uncertain about the compatibility of the file, we might need you to help us return the data containing the system information, project, and WAV files to our Technical Support.
Your project will only be used for testing problems, thank you for your cooperation.
Technical Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Daniel
