Height difference between High-poly and Low-poly character models in CC3.
https://forum.reallusion.com/Topic466881.aspx
Print Topic | Close Window
By iliakutaev - 6 Years Ago
Good afternoon. I need an optimized female model for iClone avatar. I installed a trial version of Character Creator Pipeline, I used Insta-Lod. I made an export of my own optimized Alice model to iClone, and I was surprised that the models are of different heights, and with different pivot points. The optimized version is higher by 2.54 centimeters. My question is, isn't it 1 inch? An inch was meant? I don't have any other ways to optimize the model for animation. And if this offset was removed, I would be happy.
By Peter (RL) - 6 Years Ago
Hi...
Which LOD settings did you use in Character Creator 3 when exporting the .iAvatar?
I just ran a test with a standard CC3+ avatar and then an exported LOD version and both were the same size in iClone.
For reference the default CC3 Base character is 170.20 cm or 5.58 ft.
