Memory couldn't be written error when using cc3
https://forum.reallusion.com/Topic465905.aspx
Print Topic | Close Window
By s.mamdouh - 6 Years Ago
Hello everyonehttps://forum.reallusion.com/uploads/images/105deb5b-570d-44cf-83e4-68de.png i need help when using character creator this error showed to me i tried to uninstall and reinstall it nothing happed and tried to update my laptop gpu but still have this error
By Peter (RL) - 6 Years Ago
Hi...
Sorry to hear you are having problems launching Character Creator 3.
Please ensure your system is fully updated and graphics drivers are all up to date. If you still have problems after doing that, please let us know your system specifications including graphics card. Thanks.
By Kthorxaitou2020 - 6 Years Ago
I have the same problem after install the Character creator pipeline v3.3 extension, the character creator cannot be open.https://forum.reallusion.com/uploads/images/ae066640-b3f6-4dcf-9206-50c0.png
Note: the error number is different on each time I open, but the same message
I am using Windows 10 20H2 64bit, AMD R950x, Quadro RTX4000, 1000GB SSD, 64GB RAM. DirectX 12, and the NVIDIA graphic card version is 27.21.14.6289 released on 12/11/2020
By animagic - 6 Years Ago
Unfortunately, Quadro cards are not officially supported. I don't know if that is your issue, though.
See recommended system requirements here: https://manual.reallusion.com/Headshot_Plugin/ENU/Headshot_Plugin_for_CC/1.0/ID_SysReq.html.
By cryptonyte67 - 5 Years Ago
I am also having the same problem what is causing this? I have met all the requirements and drivers are all up to date
By Peter (RL) - 5 Years Ago
cryptonyte67 (8/18/2021)
If you are having regular crashes with all projects rather than just one particular project, then please contact Technical Support using the link below. Do remember to supply your system information (dxdiag.txt) so the Support team can check for any obvious reasons for the crashing. Thanks.
