Following the course "3D Scan Pipeline"
Home
Archive
Character Creator 3
General
https://forum.reallusion.com/Topic465796.aspx
Print Topic
Close Window
By mulfycrowh
6 Years Ago
Hi everyone,
I'm following the course "3D Scan Pipeline".
I selected the base mesh "CC3_Base_Male".
I didn't succeed putting it in T Pose in CC3 but when I exported it into ZBrush, I selected the option "T Pose" and got it in T Pose in ZBrush.
My scan is not textured.
The process with Wrap ran quite good.
I got my low poly and exported it back into ZBrush.
Selecting GoZ > All let it export to CC3.
As you can check on the attached screenshot, the result is weird:
1- Hands are a little bit broken
2- I got two characters instead one in the course
3- Both characters are in A Pose
What is wrong?
Thanks for help.
Attached:
- The base mesh in CC3 when starting the process
- The low poly in ZBrush
- The result in CC3 after GoZ > All
By animagic
6 Years Ago
There is a T-pose in CC under Motion Template/Motion:
Double-click the _T Pose icon and the motion will be applied. Using a T-pose may help. I don't know, because I have never used the scan feature.
By mulfycrowh
6 Years Ago
Thanks.
Does it explain the issue when importing back from ZBrush to CC3?
I mean for example, the hands.
By mulfycrowh
6 Years Ago
Any idea maybe?
By vidi
6 Years Ago
Export the basemesh for fbxkey and
use wrap ,then this as morph mesh in the create morph panel no zbrush needed
By mulfycrowh
6 Years Ago
Thanks.
I do not understand "Export the basemesh for fbxkey".
By vidi
6 Years Ago
Fbxkey is needed for creating morphs Slider If the Mesh is deform with wrap.
