Adobe Photoshop Compatible Version
https://forum.reallusion.com/Topic465772.aspx
Print Topic | Close Window
By Wilby - 6 Years Ago
Hi! I've just accessed the trial version of Cartoon Animator 4 to see whether it will work for me. Found a free tutorial on Udemy (2D Animation 101 Courses) and following it on importing and opening up a template PSD file. I found out I can't seem to drag+copy the layers on one PSD file unto another open blank PSD file that I have. I'm not sure what is the issue... but I have a hunch. Do I have a very old version of Photoshop that is not compatible with CA4? I'm using Adobe Photoshop CS 5.1 Extended. Is there a workaround? If not, may I know the oldest version (not yet CC) of Adobe Photoshop that CA4 is compatible with?
EDIT: I think I just realized the problem. The version of Photoshop I'm using does not have the functionality yet to copy-paste Folder Layers from one PSD file unto another. :-P I hope modifications I make in the PSD file will still carry over automatically to CA4 though... Will post update later on.
I'm not sure what happened but PSD files I created in my version of Photoshop suddenly worked with Cartoon Animator 4. The feature of auto updating edits for both software works just fine and I can also click+drag layers from sample PSD template files included with Cartoon Animator 4 into any newly created PSD project file in Adobe Photoshop CS 5.1. The PSD file that didn't work for me before came from the 2danimation101.com Udemy course.
By DanielC_RL - 6 Years Ago
Good to hear that you have found the solution to the problem,
I guess the PSD files have some unknown issue that Cartoon Animator can't successfully read,
if your class needs the file to follow, may I suggest you send the PSD file or project to the technical support.
Technical Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Hope you can have a great experience in Cartoon Animator.
Daniel
Reallusion
