Error "program version is larger than the installed program'
https://forum.reallusion.com/Topic465410.aspx
Print Topic | Close Window
By Danilutz - 6 Years Ago
Hi, guys!
I get this strange error "program version is larger than the installed program', I chech for updates either from CTA or the Reallusion HOB but my CTA seems to be up to date. Any thoughts on this?
Thanks a lot!!!
By Peter (RL) - 6 Years Ago
Hi...
The Spunky Moves pack is not compatible with Cartoon Animator. You can download the pack free (if eligible) for iClone or in FBX format for use in other 3D software like Unreal, Unity, 3DS Max etc.
Thanks, Peter!!!
nice moves :))
Is that you in the CTA tutorials?
By Albert_RL - 6 Years Ago
Hi,
I'd checked with the Cartoon Animator Team,
they said 3D motions could be used on G2 Characters if you have Cartoon Animator 4.
However, they are planning to release CTA 4.4 this month,
and you'll be able to use 3D motions on G3 characters.
(More info will be released in the CTA thread)
If you wish to install Spunky Moves into your CTA program,
please re-download the RLD again, after installing the motions shall appear in your content manager.
https://www.reallusion.com/event/freeproduct/default.aspx?cid=229&chk=e0d72c56701d6d6ff7abfc2e1ec6f730
If you continue to see the error message,
kindly contact our support team and provide a screenshot of the message.
Hi Danilutz
As Albert already mentioned you can now use the Spunky Moves pack in CTA but you will need to install a little differently. Please see the page below for instructions.
https://forum.reallusion.com/465481/Solved--Fail-to-Download-ActorCore-Free-Motion-Pack-Spunky-Moves#
