Cartoon Animator 4 will not load popVideos
Home
Other Reallusion Products
popVideo 3 - Transparent Video Creator
https://forum.reallusion.com/Topic465291.aspx
Print Topic
Close Window
By General Picture Animation
5 Years Ago
I'm striking out trying to load popVideo files in Cartoon Animator.
All I ever get is Failed to Load File.
Yes, I have installed the K-Lite codec pack.
Help?????
By r78zj99
5 Years Ago
Hi hicksight
maybe your file is corrupted
so do a feed test
and see, how you get with your new file.
from Alan
5 Years Ago
Hello... I don't understand your directions.
r78zj99 (12/6/2020)
Hi hicksight
so do a feed test
from Alan
By r78zj99
5 Years Ago
sorry I miss out the word (back)
see picture
from Alan
By toystorylab
5 Years Ago
So, I have no problem with Popvideo.
These are all popvides (custom + RL):
Drag and drop and select prop...
So, yes, your file might be corrupt.
5 Years Ago
OK, THAT worked... now I have to figure out what else is going on.
5 Years Ago
Thanks for telling me that there is actually a PopVideo app.
What I have found is that a popVideo from iClone is not recognized.
After I *RE*-export the file from the PopVideo app, it works.
But there are problems.
Placing a PopVideo into a CA4 composition, and then exporting the animation in popVideo format causes bad artifacts in popVideo which I imported.
By r78zj99
5 Years Ago
as you now realize K-Lite codec pack
has nothing to do with popvideo
some software company's make their own versions
who told you to feed a video back on it self (nobody does that)
I had made the chart clear to you to understand just using your project file again to remake your popvideo then simply replay it again.
don't forget to click the new button first
from Alan
