About Iray using Gpu rendering settings
https://forum.reallusion.com/Topic464617.aspx
Print Topic | Close Window
By a-shue34 - 6 Years Ago
Hello everyone, I am a newbie user of iclone
In the past few weeks of use, I have been collecting various information on the Internet
The most troublesome is rendering pictures or videos
First, I use the iclone preset renderer. I think the effect is not very good. I always feel that light and shadow are too stiff.
After using iray, I think this is exactly what I like
But because I am a member of Premiere, the graphics card does not need to be too advanced, so it is an RX570 from ancient times.
CPU is AMD 3900X, Ram 32G
I saw information about iray on the Internet, saying that it supports nvdia GPU computing, so I reluctantly bought RTX 3080
No matter how you set it up after you go home, iray’s calculation speed cannot be improved
Same as before, it is 100% cpu
What's the problem?
By sergey.vienna - 6 Years Ago
Nobody anwsered :-) I have the same problem. I found only one information about GPU anabling. This is was done through INDIGO plugin ... Now will look it... ) If you found something please let me know. I want to make enable rendering using my Nvidia RTX 3090
By 4u2ges - 6 Years Ago
To begin with, check your Iray Render Hardware Settings and then enable and check the log in the Iray Preview window.
Also, monitor your GPU with GPU-Z utility: https://www.techpowerup.com/download/techpowerup-gpu-z/
https://forum.reallusion.com/uploads/images/0b5fe614-fc2c-4b54-8f1f-beea.jpg
Yes! I have the same settings in my character creator (iray settings). Please look at attached picture..
But in the lohg file you can see: No usable device.
I checked DAZ3 studio and redering (iray) used my Nvideia RTX 3090 without ptoblem.
Here just black screen and NO USABLE DEVICE :-(https://forum.reallusion.com/uploads/images/f8df908b-5394-4956-936c-26fb.jpg
By StyleMarshal - 6 Years Ago
Yepp , my RTX3090 card is not recognized by IRay too , guess there comes an Update very soon.
It is strange, because it is recognazed in DAZ3D software...
By animagic - 6 Years Ago
Has this been reported in Feedback tracker?
animagic (12/27/2020)
I have sent 4 days ago about this to reallusion support. But still did not got the respond..
OPS..
Right now I have got the respond from the support team:
Dear Customer,
Thank you for contacting Reallusion.
We are working on an update for the RTX 3000 series cards. In the meantime you can download the beta. Please let us know if it is woring for you.
1.Go to the "Shared Plugins" folder at your iClone installation path.
  (ex. C:\Program Files\Reallusion\Shared Plugins)
2.Find and rename your "IClrayRender" Folder. (ex.ICIrayRender001)
3.Download the Beta Version by the Download Link:
[Link Removed By Moderator]
4.Extract the "IClrayRender" Folder in the zip then copy to the Path mentioned in step 1
P.S :
I have tried this 5 minutes ago... Nothing work :-( The problem not resolved.
By Thunder70 - 6 Years Ago
Hey thanks,
I have tested this beta and it works for me.
I have a RTX 3080
RTX3090 does not worl :-(
