By tbseo - 4 Years Ago
Is there a way to use auto mode to generate the initial face and then somehow get the higher resolution of pro mode? I'm finding a lot of faces I generate in auto look great right off the bat but pro mode requires a ton of tweaking just to get the same result but with higher resolution. Is there a tutorial out there somewhere to do this?
By Rampa - 4 Years Ago
Do it in two passes.
Capture in Pro mode. Save the skin in the Content Manager. Capture the same image again in Auto mode. Load the hi-res you saved from the Pro mode.
Bonus: You get some hair!
Thanks. I'll give it a try.
