2d Rotation
https://forum.reallusion.com/Topic463728.aspx
Print Topic | Close Window
By declanwalshart - 6 Years Ago
Hi,
Many thanks for allowing me the opportunity to look at this process early.
I was getting to grips with it today, and just one thing kept coming up for me. Some limbs foreshorten, it would be amazing if the torso and hands did this.
My main question is there a way to have the body switch from front to 45, to the side so the motion created in 3d like a turn could be mimicked in 2d without swapping out the angles.
Hope that makes sense
Thanks
Declan
By kylelee - 6 Years Ago
declanwalshart (11/18/2020)
Hi,
Thanks
Declan
Thank you for your feedback.
Currently, you can switch show/hide to change different angle characters such as from front to 45 degrees.
At this current stage, Cartoon Animator still doesn't have the ability to turn the body for G3 characters.
You can pass the suggestion to Feedback Tracker.
At this current stage, Cartoon Animator still don't have the ability to turn the body.https://www.reallusion.com/FeedBackTracker/Product/Cartoon-Animator-4?IsSearchReleaseVersion=False&ProductVersion=4.4%20Early%20Access
Hi,
Thanks for that, a good idea I didn't think of. I will run a test on this :)
All the best
Declan
By studio.diba - 6 Years Ago
Hi Declan,  You start with a side pose, switch to a front pose in the middle and end with a filp of the side pose.
https://forum.reallusion.com/uploads/images/2567fef9-34b0-4c17-93e4-99c9.gif
Hi,
Thanks for that, I can see it now :)
studio.diba (11/19/2020)
You can try enable the "Flip body" when applying 3D motion that will easier to do switch front to side.
https://forum.reallusion.com/uploads/images/ed8e7651-12ff-4e98-af43-3e21.png
