By Seeker123 - 5 Years Ago
I've HP Omen i7 7th Generation with GTX 1050 4 GB graphic card. Is it enough for rendering and other operation? How much rendering speed I can expect? Does rendering speed depend on number of polygon' faces or vertices? If yes, then how much face count limit should I preferably keep to get a nice rendering time? Plz share your experience.
By Kelleytoons - 5 Years Ago
The 1050 is about a slow a card you can get -- it is *barely* able to work properly with iClone (might not, even -- usually the recommendation is a minimum of the 1060).
I would STRONGLY recommend you consider getting another card (right now the least card to get would be a 1080, which you might find used at a reasonable price).
By gordryd - 5 Years Ago
I use a 1050 TI (4GB) and it can handle the various programs (iClone 7, CC3 Pipeline, 3DX Pipeline, etc.) fine. As far as rendering speeds, it is what it is, so just schedule your renders during dinner, or overnight,or whenever. The biggest drawback lately is the memory size -- 2 of the CC3+ characters in a scene pretty much maxes out the memory. I will probably upgrade to the RTX 3080 TI w/20GB (when/if it's officially announced) to reduce memory limitations...
