By chrysgaman3 - 6 Years Ago
Hello from French, my name is Christopher Gaman and I am 3D modeling indie. Sorry for my wrong english. Thanks for watching my work Wip for the contest. This character is inspired by the spiritual world and I opted for intercessor. They are people endowed with god's power through the Spirit. They can fight demons and dominations, intercessors can also heal the sick and conveyed Love according to God. I made this character from the picture of an apostle. For his armor, I thought it was good to attribut him something reminiscent of that of the Romans in the year 33. This character is also intended to take place with other classes of combatants in a TPS/FPS-type war and survival game that I develop with my brother. I heard from CC3 and its pipeline for UE4, so I decided to grab these wonderful apps to bring to life the projects I have in mind. This contest falls to take advantage of Reallusion's tools. I attach screenshots so you have a beginning, during, and finalization of the character. Thank you
After finding the composition that suits me, I sent it on Zbrush with the GoZ and finally I removed the hair since the character will own a helmet.
 Ref for the armor of my Intercessor character
Using the extract, I began to paint the articulated part of the suit.
With the same way, I then worked on the armor creating basic shapes to get an overall idea before moving on to the details
By matenn30 - 6 Years Ago
It is precise and delicate. It's just Western armor. I also want to see the coloring. 緻密で、細やかです。まさに西洋鎧です。色付けも見たいです。
Thank you very much for your words. Are you Japanese? I'm sorry, my Japanese has become bad. It is mainly when there is a color of the character tomorrow. Thank you again. あなたのことばのこと、本当にありがとございます。日本人ですか? すみません、ぼくの日本語はわるいになったから。 明日かな、キャラクターの色があると主います。またありがとございます。
I continue to add more parts to his armor to get the desired vision.
I will now work the helmet by adding a sphere that I stretch with the brush "Move"
After digging the inside, I continue adding volume with the "ClayBuildup" brush
With the combination of different brushes, I finally get my helmet
I am Japanese. Do you use substance painter via steam for texture coloring? 日本人です。テクスチャー色付けはスチーム経由のサブスタンスペインターを使用しますか。
はじめまして、ぼくはフランス人です。ニ会め、日本に行ったよ^^ とっても楽しかったです。 ごめんなさい、おしつもんあまりわからない、けど、Substance Painterの事をつかいます。あなたも3Dのアーテイストですか? I'm happy to meet you, I'm French. I've been to Japan twice. It was a lot of fun. I'm sorry, I don't understand your question, but I use the Substance Painter. Are you a 3D modeler too?
I like the helmet, I add the mouth guard (I'm not sure of the name). I also worked on the underside of the armor, you know the combination that we see in some movies there, the neck of the character is better protected.
Here I added a metal mane to make a reminder about the armor of the Roman era.
Thanks to the "mask" brush of zbrush, I can draw on the simplified sculpture of the armor to further detail its shapes
The shoulder pads suit me well, then I start working on the breastplate that encompasses the torso and back.
More and more pieces for more details and reliefs.
I finish this part of the armor by the torso that comes protected the heart of the Intercessor. A pretty thick and well-armored piece.
Je suis un fournisseur iclone (développeur). Le rang est ccd. L'URL est ci-dessous, traduite en français par Google translation.
We're finally attacking the parts of the arm
Hum, I initially thought about putting gloves on him too but finally I didn't keep the idea, I thought the Roman soldiers weren't wearing gloves, maybe I'm wrong but it doesn't matter, I find it better as well. On this screenshot, I added the elbow protector
The knee pad in basic shape and then in the photo after adding details.
No boots, I opted for special sandals.
3 view character views display without details.
And now, 3 view character views display with details.
I will then switch to blender for UV's and make the weapon.
Si vous ne le vendez pas, je pense qu'il vaut mieux le vendre ou le distribuer gratuitement sur Market Plus plutôt que chez la concurrence. Vous avez plus de talent et de compétence que vous. c'est vrai. もし販売していなければ、これはコンクールより、マーケットプラスで、販売もしくは、無料で配布したほうがいいと思います。あなたには、自分より才能と技術があります。これは本当です。
返事おそくなってごめなさい。あなたのことばはおもしろいと思います。よんでをよって、嬉しいになります。ありがとございます。 たぶんいつか、Reallusionのためにはたらくかな?ぜんぜんしらない。 あなたのページのIcloneベンダーはおもしろいそ。お仕事いつからはじめていますか?むずかしですか? Excuse me for the belated answer. I think your words are interesting. I'm glad to hear that. Thank you very much. Maybe someday it will work for Reallion? I don't know at all. The Iclone vendor on your page looks interesting. When have you started your work? Is it difficult?
Some catches for UV's, with Blender 2.8 the first are the arms, helmet and shoulder pads. I also removed unnecessary faces from the armor to prevent the total mesh from being too heavy.
A 3-shot shot with UV's
Les ventes ont commencé vers 2010. C'est assez difficile à vendre. 販売は、2010年くらいから始めています。売れるのは、結構難しいです。
Thank you for your reply. Iclone's job, good luck! What kind of soft-woo's do you use? お返事ありがとございます。Icloneの仕事、がんばって!どんなのソフトウヱェヱを使ります ?
I have a little problem with substance painter, I can't make the rendering (iray) so I'll quickly create the armor material in blender 2.8 Meanwhile, I add here the different channel to get the desired texture.
// Base Color //
// Metalic //
// Normal //
// AO //
// Roughness //
// Emissive //
// Helmet Material //
For the thermal and waterproof combination, I added the material of substance painter "Artificial Leather" nevertheless, I combined with a normal map of Quixel megascan and modified the scale to "128" to get the fibrous effect I wanted.
Here is the shader under blender 2.8 and the following screenshots are lighting tests using HDRI uploaded to HDRI Haven to see if all goes well with the armor.
Le logiciel que j'utilise principalement est zbrush core, substance spanter, sketch-up shop et sketch-up 8. 自分が主に使う使用ソフトは、zbrush core,サブスタンスペインターのほかに、スケッチアップshopやスケッチアップ8です。
My character is ready but I'll try to add his weapon and used the remaining hours to finish it. It's an exciting contest.
// Wip // Concept made before under Manga Studio 5 and import under Blender 2.8 for ref
It takes patience. I am devoting myself every day. I hope the purpose is achieved. 根気がいりますね。日々精進です。目的が達成するといいです。
By LookingGlassGraphics - 6 Years Ago
Incredible detail on the suit. This character looks awesome.
Update Wip Weapon
Now I will finishi the mark seam and the UV's, after that, go to Substance painter ! I will work all the night I think.
@Matenn30, Sorry, I'm late ! After my night I will safely reply to you.Thank you for all your message. Courage at you !
LookingGlassGraphics (2020-11-17) Incredible detail on the suit. This character looks awesome. LookingGlassGraphics, Thanks, I saw what you did "The Pitt", I especially like the rendering image, GG!
matenn30 (2020-11-17) It takes patience. I am devoting myself every day. I hope the purpose is achieved. 根気がいりますね。日々精進です。目的が達成するといいです。 @Matenn30, Sorry, I'm late ! After my night I will safely reply to you.Thank you for all your message. Courage at you !
A few more to finish and then head for the textures. // Wip UV //
Finishes, before assembly for revolving delivery video. I show you a few steps in my texture. I used the same material as for my character's armor and I just slightly changed the color but the weapon remains matched with my warrior.
I applied emissive, always in order to stay connected with the character.
I then painted the muzzle of the cannon, it is huge, it is a huge ray that comes out, so it has traces of wear a little burnt.
I like it, there's more than to make the tourntable video
Here we are, my character is sent to Reallusion. I was really happy to participate. Here's the finished character. (For the cra contest afterwards, I'll continue to work on his equipment for the video game).(For the cra contest afterwards, I will continue to work on its equipment for the video game). Thank you to everyone I spoke with during these few days. And thank you especially to my God, the Lord and Reallusion for this great contest.
