By bitstudios1 - 4 Years Ago
By Slayerazazel - 4 Years Ago
Are these all separate entries? As you don't need a forum thread for each individual update. That will FLOOD the forum thread. It's a general rule of thumb to just repost your updates in 1 single thread.
By Sifr - 4 Years Ago
You can post an update to your Character Creator Digital Human Contest 2020 by simply replying to your post down at the bottom of your post feed. This will help to keep your project all in the same post, instead of creating a different post for each project post entry.
Thanks for the info. Will do. How do I delete the other post so I can add WIP under one post? I do not see option to delete posts.
You can't delete posts unless you are a moderator/administrator. So probably consolidate all your posts into 1 post, and then post in the others asking for a moderator/administrator to delete.
One entry.
Message Peter or Miranda, explain what you want to be done. Make sure they don't delete the post you want to keep. Add the links to the posts you want to be deleted in your message. https://forum.reallusion.com/Users/8/Peter-RL https://forum.reallusion.com/Users/2818406/Miranda-RL
