24fps FBX export truncates animation clips in Unity
https://forum.reallusion.com/Topic462721.aspx
Print Topic | Close Window
By jerome.dipietro - 6 Years Ago
Here's a heads up for anyone exporting iClone animations to Unity. If you pick 24FPS as your export framerate then the clips when imported into Unity will have their duration truncated.
Here's what's imported (Mesh import settings > Animation tab):
https://forum.reallusion.com/uploads/images/359ca736-5e56-4e38-a3b7-d010.jpg
All you need to do is to extend the end bracket to the last frame:
https://forum.reallusion.com/uploads/images/baade18f-b5f1-4bfd-874d-758d.png
For reference, here's a normal 60FPS import. Doesn't have that problem and automatically ends on the last frame:
https://forum.reallusion.com/uploads/images/9e88aaa1-181d-42b0-87e7-ecc5.png
