By themajestic.3d - 6 Years Ago
Hi everyone,
I have a problem with Iray and my RTX 3080. I have tried to render an empty scene using the GPU and the iray preview window only shows the "loading..." label. If I use the CPU, the scene is rendered, but with the GPU (without CPU), it's impossible.
Are there problems with this card?
Thank you very much
By StyleMarshal - 6 Years Ago
IC 7.8 Iray is not recognizing the new RTX30.. cards ( log: found no useable cards) , guess there is coming an update very soon.
Thank you very much. Then, We will wait the new version.
Greetings
Hi,
when iray will be updated to work with rtx 3000 series?
I guess with IC7.9 - should not be far away.....
By Peter (RL) - 6 Years Ago
themajestic.3d (12/29/2020) Hi,
We currently have a beta version fix for this issue. Please contact Support using the link below and they will be able to let you try it.
By DoronT770 - 4 Years Ago
This an old post, did it change? does iclone8 iray supports rtx3080 by now?
By bad_character - 4 Years Ago
Yes
By eternityblue - 4 Years Ago
So iClone 7 is broken, I doubt it ever will be fixed, and iClone 8 has no hobby entry level point :(
Someone please tell me I'm wrong about this. I'm poor and the only wat to get a discount is to have enough money to buy both CC4 and iC8 at the same time. It is pretty absurd that the world works like this.
I bought everything nearly and upgraded to iC7 Pipeline. And now I have to buy it all again for iClone 8? I think I should just give up on Reallusion since they gave up on people like me and stick with Blender. man this sucks.
By animagic - 4 Years Ago
eternityblue (8/28/2022) So iClone 7 is broken, I doubt it ever will be fixed, and iClone 8 has no hobby entry level point :(
What is wrong for you in iClone 7? It still works for me.
