CC# Pipe Dark Renders
https://forum.reallusion.com/Topic461361.aspx
Print Topic | Close Window
By JasonWynngard - 6 Years Ago
Suddenly, when I render an image with CC3Pipe, it comes out dark as if the character is standing in a heavily shaded area or dark hallway. I've fiddled with the  lighting options, and indeed at times the character and scene is crystal clear. But when rendered, they are dark. The only way I can obtain a decent image is to use SnagIt to screen capture it. I then save it over to Paintshop Pro to use as intended (usually book cover work). If I need further lighting work, I employ the Graphic GRX plugin. But in the past, I didn't need to do all this work, CC3 rendered images just as I wanted them. If anyone can assist to help me correct this sudden phenomenon, I will certainly appreciate it.
https://forum.reallusion.com/uploads/images/4e34e2e7-4139-40f4-be20-c02a.png
