Can't Get Collect a Clip to save my transformations to action menu
https://forum.reallusion.com/Topic460815.aspx
Print Topic | Close Window
By poemstudios - 6 Years Ago
I go into timeline click collect clip
then select the range of keyframes
save to action menu
or save as a motion clip
then I apply it and nothing happens
what am I doing wrong?
anybody>?
By Ntar - 5 Years Ago
Seeing the same issue. Is there a fix or am I doing something dumb?
By vepop - 5 Years Ago
Is it for a prop?
Yes. For example, a wavy blue line for waves, I want to record a bobbing motion. Up, down, several times. Follow all instructions, movement just doeesn't "take" but the new "action" gets recorded, only it doesn't seem to record any key frames.
I was actually hoping to get an answer to this. I guess the answer must be you can't attach actions like that to pops then.
You have to use the prop key editor to key frame the motion.
Then, use the Collect Clip.
Of course! Thanks so much. I was foolishly just moving them about on screen expecting that to work!
