Video Memory
https://forum.reallusion.com/Topic460214.aspx
Print Topic | Close Window
By lvanvalk - 6 Years Ago
I am getting very frustrated. My character's legs still don't move right when she is running. She just slides across the scene only moving her legs once. I upped the speed to 150% and exaggeration to 125%. When I originalyl asked about this problem I was told because I didn't have enough video memory so I bought a new computer with L3 cache, 6 cores) + NVIDIA® GeForce RTX™ 2060 w/Max-Q design (6 GB).
Do I need to just keep upping the speed? I can't buy another computer again.
Thank you,
Lorraine
By animagic - 6 Years Ago
Did you try the Quick or Minimal shader for the project to check the animation? That may help.
You have a fairly large project (over 1M triangles) and although 6GB is OK it would have been better to get a card with more VRAM.
By gordryd - 6 Years Ago
All walk/run motions are not built the same.  Some have both motion (legs moving) and movement (translation).  Some have only motion and you provide the start/end points (translation).  It sounds like maybe the run motion you chose only does has motion for one cycle -- check on the timeline to see how long the animation is.  If is fairly short (<30? frames) it's probably only doing one cycle.  Click and drag on the end of the animation clip in the timeline to copy/extend the animation.  If that fixes the running portion you will need to adjust either the start/end position (if time is fixed) or start/end times (if length is fixed) to get realistic stride length and minimize sliding.
