Live Link prop in wrong position when linked
https://forum.reallusion.com/Topic460182.aspx
Print Topic | Close Window
By cinemyscope - 5 Years Ago
https://forum.reallusion.com/uploads/images/a40580d6-4e1e-48db-b456-40cf.jpgHi,
So I got a new scene and I'm having two problems with my live link.  I'll make this two seperate posts.
Problem 1:
The character interacts with multiple props.  I transferred the props and while most are in the right position and line up perfectly fine when Live Link is active, one prop is way off and moves with the link but in a completely wrong spot. in the UE scene. Any ideas how to fix this?
I am attaching an image showing the prop and it's positioning inside iClone and where it ends up in UE.
I appreciate all your help!!!!
Thank you!
Well I got that one "fixed", though I'm honestly not sure why.  I re-imported the model into iClone and before animating it did a re-set to zero and a re-set scale after I scaled it to the right size.  That scale reset seems to have done the trick thogh I have absolutely no idea why this was an issue with that particular prop and none of the others.
The lesson learned here is to import everything through Live Link prior to doing any animation in iClone, to make sure it goes over right.
That said I'm still stuck with this one:
https://forum.reallusion.com/460187/UE-Data-Validation-FAILED-on-Live-Link-transfer
Any help would be greatly appreciated!!!
Thank you!
