By evwalker10 - 6 Years Ago
Hey guys,
Just got iClone and made my first animation. Then I transferred and linked everything to Unreal using the Live Link plugin and it transferred all cameras, props, and lights just fine. I noticed my characters didn't make it so I tried to transfer again...nothing. I tried to link and noticed errors that say:
! Trying to add more than 64 frames in the same frame. Oldest frames will be discarded. ! Upgrade your code. Curve elements count has changed from the previous frame. That will clear the previous frames of that subject. ! Can't evaluate frame for "Character 1". No data was available. ! Can't evaluate frame for "Character 2". No data was available.
Anyone know of a fix? Thanks!
By oisilener1982 - 6 Years Ago
Try to Rename your character then transfer it again.
By cinemyscope - 6 Years Ago
Hi, I can't guarantee this will work, but I had issues trying to transfer characters and props at once. Try transferring everything one by one and see if that works. Hope this helps!
Unfortunately, these didn't work for me :/ Thank you tho
Have you tried transferring the default character?
By rosuckmedia - 6 Years Ago
@evwalker10 Question have you installed the current Auto Setup Tool. Best regards rosuckmedia:)
I’d second the suggestion of rosuckmedia. Check your plug ins. Unfortunately Reallusion IMO keeps changing things in a way that the online resources on how to install the plugins are very convoluted. Make sure you also have your Character Creator plugin installed in UE. Those plugins are your most likely issue at this point. Good Luck!
