Pressing Play Button Makes Timeline Go Back to Frame 1
https://forum.reallusion.com/Topic459072.aspx
Print Topic | Close Window
By monkeyjediflame - 6 Years Ago
Hi,
[UPDATE 2: Mystery solved. I found a red marker in the timeline that 2as causing the problem. This is likely a bug. If you update the total length in frames and then change it again, it won't move the red marker to where the ne2 end of the clip is.]
I'm animating a long clip. Whenever I added a preset human motion, it used to replay that new motion. Then I could go to the frame just before the motion, press play, and then watch it while hearing the audio. Then, that all stopped. Now, It won't play the motion I just added. On top of that, when I Move to the frame just before it and press the play button, it goes all the way back to the beginning, frame 1. Instead of being able to start and stop with the pause and play buttons. I have to start from the very beginning. The only thing I can do now is scrub to see what a motion looks like. I can't even make out the words.
This happened at random times during the last two projects in CTA4. Is there a fix for this? I don't have time to spend the extra hours using only scrubbing. Thanks.
UPDATE: The problem only occurs past a particular frame. Before that frame, I can press play, and it will play from where the timeline pointer is. After that frame, and the play button goes back to frame 1. In Project Settings, the end of the timeline is pretty far into the future. I'm also noticing that, every single time I add a motion, it jumps back to frame 4000.
