CTA 4 Question. Changing the sprite on a Special FX Object Template (Burst with joy)
https://forum.reallusion.com/Topic458895.aspx
Print Topic | Close Window
By rica_608756 - 6 Years Ago
Good day Minnie and Peter,
I would love to use the "Burst with joy" FX object Template, but would like to add bees and not the flowers.  I tried to go in to the sprite editor, but
unfortunately with special effects it only shows the flower template and a empty sprite.  How would go about saving my bee sprite or changing the sprite of
the flowers?
I also tried to collect the motion, but was unable to.  I am a newby and not sure if this would be possible?  Any suggestions?
Kind Regards
Rica
By Peter (RL) - 6 Years Ago
Hi Rica
The SFX included in CTA4 are all animations in the Flash FLV format. Sadly you can't simply change the sprite to another image with these type of effects.
Thank you. Peter.
By sjonesdc - 6 Years Ago
Peter (RL) (9/28/2020)
Hi Rica
So, will the SFX included in CTA4 work after 2020, due to the end  flash and any support for flash?  If so, what would be the method to convert the files into a format that is usable?
