CTA4.3 - Cartoon Animator - AE Script (Beta) - Introduction
https://forum.reallusion.com/Topic458471.aspx
Print Topic | Close Window
By Minnie (RL) - 6 Years Ago
What is Cartoon Animator - AE Script (Beta)
This is a AEscript that expedites 2D animation import workflow between Cartoon Animator and After Effects. You can import your animation work processed in CTA to AE effortlessly with just one click. It supports layered and transparent sequences and scene export. By bringing layers of sprite from CTA to AE, users can perfectly edit every element in post production while preserving all animation keys. For users without AE, they can select and group animation assets and export as image sequence then edit in other post production software.
Check out our webpage : www.reallusion.com/cartoon-animator/ae-script-animation-vfx.html
CTA Download: https://www.reallusion.com/cartoon-animator/download.html
 Install CTA Script in After Effects
Export CTA Project to After Effects
Enhance Your CTA Project in After Effects
Requirement
1.  Cartoon Animator - AE Script (Beta) is an AE script associated with software Cartoon Animator. User must have installed the full version of Cartoon Animator 4.3 to run this plug-in.
You can click here(AE Landing, link to be embedded) for more information about Cartoon Animator
2. To run this AE Script for Cartoon Animator (Beta), please make sure your After Effect software compatibility: CC 2020, CC 2019, CC 2018, CS5, CS6
3. You need to install/ update your Cartoon Animator 4 software to version 4.3 to run AE Script for Cartoon Animator (Beta)
How to install  Cartoon Animator - AE Script (Beta)
1. Find "ScriptUI Panel" folder in the following location:
Windows:
Adobe\<Adobe After Effects 2020>\Support Files\Scripts\ScriptUI Panels.
MacOS:
Applications/Adobe After Effects CC 2019/Scripts/ScriptUI Panels
*Note: If you can't find them then create a folder with the name "ScriptUI Panels".
2. Copy " Cartoon Animator - AE Script.jsx" into the folder.
3. Restart After Effects, and navigate to Windows> "Cartoon Animator AE Script.jsx" . Click on it, then you will get a float panel. You can dock the panel in your workspace in AE.
Learn & Support
You can learn more about how to use  Cartoon Animator - AE Script (Beta) via
By snichael - 6 Years Ago
FYI: the link above for "Online Manual" doesn't work.
@snichael
The link has been updated. You can also refer the below link to the manual page:
https://manual.reallusion.com/Cartoon_Animator_4/ENU/Pipeline/Content/Resources/4.3/11_Export/Smart-Export-to-After-Effects.htm
Thank you!
