Make light options the same for IC7 and CC3
https://forum.reallusion.com/Topic458363.aspx
Print Topic | Close Window
By 0oseven - 4 Years Ago
IN CC3 there is an option to apply an " image" to a light,also "light shapes" but not in IC7.
Request  same option in Iclone7 which only has the colour palette .
Or maybe option to export Lights with Character from CC3.
Exporting as fbx and reimporting via 3Dexchange would be clumsy worlflow  - IF it works that way ?
Cheers
EDIT Have added to feedback tracker
By 4u2ges - 4 Years Ago
There is no difference between iClone and CC lights.
Well, there is Smile. CC uses Spot lights in the default project while iClone uses Directional lights.
Spot lights (and Point light as well) can have images/shapes applied, while Direction lights do not have that option.
This is true for both iClone and CC and you can have any type of lights in both.
By animagic - 4 Years Ago
I think it is good to ask here first before adding to FT in order not to overwhelm RL. I added a comment to the FT entry.
