Issue with the photo projection (Headshot plugin)
https://forum.reallusion.com/Topic457555.aspx
Print Topic | Close Window
By MiddleEnd - Last Month
Adjust lip seam height using headshot morphs and then reproject the photo?
By animagic - Last Month
MiddleEnd (10/1/2020)
A good suggestion.
Another adjustment to make is lip corner. After that re-project, and the result is much better:
https://forum.reallusion.com/uploads/images/50a0d9fc-4860-4b7e-9629-198d.jpg
By Tanaka-Seijin - 2 Months Ago
Hello everybody. Everything projected as expected except for the lips. As I see it, I don't think it's a problem with the photo itself that it's at a high resolution and symmetrical. Anyway, could someone tell me what should I do to correct that issue please?
https://forum.reallusion.com/uploads/images/6fff957f-715b-4c1c-bec2-074b.jpg
By Tanaka-Seijin - Last Month
Thank you for the tip!
Thank you. It's the first time I use this software and my first photo projection as well.
