Use AI to generate head !!!
https://forum.reallusion.com/Topic457372.aspx
Print Topic | Close Window
By tim.bradbury - 6 Years Ago
Headshot must retire the outdated 1k (horrible results)  and 4k textures and replace, or provide the user with the option to choose, 8k textures!
The purpose of software is to make life easy. Currently, headshot has too many options that must be tweaked to get the face looking similar to the base original photo.
Reallusion must integrate AI to make much more realistic faces quicker.
Currently, the generated face skin stops and we can see the edges. Then we must use many tools to blend the edges.
BUG: a generated head side profile looks flat.
Horrible!!!
Reallusion should use AI to create skin for the ENTIRE head and body based off a single original photo.
See example:
It should not take hours or days to make a realistic head. AI can make this process almost instantaneous!
By animagic - 6 Years Ago
We should go further, and have iClone make the movie too! :P
Actually, Headshot already uses AI to generate the head...:sick:
By 4u2ges - 6 Years Ago
I was talking about improving headshot profile match from day one. And Dennis has an FT ticket:
So vote and comment there: https://www.reallusion.com/FeedBackTracker/Issue/Headshot-Support-left-and-right-PROFILE-side-Image-Matching-overlay-images
By Amper Sand - 6 Years Ago
@tim.bradbury
I had a good laugh reading your post, because its requirements made me think of those blockbuster movies where somebody zoom-in a pixel to construct the whole Manhattan where zooming more there is a girl having a small tattoo under her left arm.
On a serious note: better suggest those website you mentioned to provide an "export as FBX" feature for the heads it generates, would be much simpler. Headshot's tweaks and sliders has their own, clear purposes, as the 1K resolution you mentioned. If you think, an audio recording studio has hundreds of sliders, or, even better, have you ever seen a Moog synthesizer? You cannot play anything on it, rotflmao :)
What's interesting also about the website provided by the OP is that all photos are front view only and fairly low resolution. So where do the side view and 8k textures come from?
By auwebber23 - 5 Years Ago
Tell me, please, what else is interesting to do with AI? I know it adds realism, but what else is it used for or planned to be used for?
