How to remove/edit bone animation keys of Character?
https://forum.reallusion.com/Topic456037.aspx
Print Topic | Close Window
By cgi_468384 - 5 Years Ago
Hello,
for sure a noob question, but I couldn't find out...
1.) I have a motion clip (actually only a pose) and added some keys for rotation for the arm.
But I can't find them anywhere in the timeline nor in submenus.
Where are those keys hidden? Are the merged into the motion clip?
(Now I deleted the whole animation and added again the pose, but this is not helpful for animation purposes)
2.) If I add a pose to a character it gives me a 200 frames motion clip. How can I reduce the length of this motion clip?
Actually it only needs that to last for the first frame.
Thanks
By hirospot - 5 Years Ago
Re: How to remove/edit bone animation keys of Character.
Hello,
 1)  Following images are my understanding for your question.
  ① The character is located on the iClone screen.
  ② A Pose is added on the Character.
  ③ Added some keys for rotation for the arm.
  Fig1. Sample image for ①, ② and ③.
https://forum.reallusion.com/uploads/images/8691a129-3bd1-4318-bc9d-2492.jpg
2) How to reduce the length of the motion Clip.
 ・Drag the Play Head to move back to your desired time frame. (Blue)
 ・Click the triangle button to show the sub-tracks and keys. (Yellow)
  Fig2. Drag the Play Head to move back to your desired time frame. Click the triangle button to show the sub-tracks and keys.https://forum.reallusion.com/uploads/images/e6960ebc-6b44-4749-a7d4-ae61.jpg
3) Double click on the key you need to edit to show the Edit Motion Layer. (Pink)
  Fig3. Edit Motion Layer Panel
4) Click on the key you need to remove and select remove on the popup panel.
  Fig4. Click on the key you need to remove and select Remove on the popup menu.
https://forum.reallusion.com/uploads/images/14f59027-e522-49b4-83bc-937e.jpg
Thank you,
Hiro
great, many thanks.
