Edit Motion Layer Panel not working
https://forum.reallusion.com/Topic455934.aspx
Print Topic | Close Window
By ceo_607553 - 6 Years Ago
As we were working on manual animation when i click 'Edit Motion Layer' not opening the edit motion panel. it is activating Link Icon, This is a new problem, as we had been working on this without issue till yesterday.Please see below attached imagehttps://forum.reallusion.com/uploads/images/3a5428a4-d155-487b-acfd-d7da.jpg
By Zeronimo - 6 Years Ago
Could it be that your character is not an iavatar but a Prop (obj)?
whitout a RIG
By 4u2ges - 6 Years Ago
It could possibly be off screen. Try increasing screen resolution if you can, move the panel to the center and restore resolution.
I think you're right, I said something stupid, because if it was a Prop the "Edit Motion Layer" option wouldn't appear.
Sorry, but I'm not wide awake yet.
By hirospot - 6 Years Ago
Re: Edit Motion Layer Panel not working
1. The Link button should become active when the Character is selected.
2. The Link button should be changed to inactive when the Edit Motion Layer is selected.
My observation: The Link button in your attached image is inactive, that means you selected the Edit Motion Layer already.
My guess:  The Edit Motion Layer panel must be moved outside of your screen somehow and not visible.
Fig1.
The Edit Motion Layer panel must be moved out of the screen and not visible.
https://forum.reallusion.com/uploads/images/10d85e3d-9357-4ce8-b3d2-d988.jpg
Please try changing the screen resolution
tentatively by Mouse left click on the screen to display the Edit Motion Layer inside the screen again.
Thank you,
Hiro
With a single click the panel is displayed, but with a double click the panel is displayed and then disappears.
Maybe that's the problem ... the double click...
