By trafalgamer - 6 Years Ago
One of the best ways you can optimize your game is to reduce the draw calls, this is why Merge UV is an excellent feature of CC3 because you can reduce the number of materials in your character. Unfortunately I haven't managed to make it work no matter what I do, I've tried with CC3 and CC3+, no clothes, no eyes and teeth, different skins, changed the normal map type..
Here's an example with the default CC3+ base male, I'm using UE 4.25 and have experienced this in 4.24 as well with a CC3 base character. Creating the materials manually without using auto setup didn't help.
So far everything leads to a bad normal map but could it be something else ? Any suggestion or help is very appreciated, thanks.
By 4u2ges - 6 Years Ago
Yes, that is a case of bad normal stitching algorithm. I got the same in Blender. Got to have a cloth to cover it :). Or take it somewhere else to merge materials. Or submit the problem to FT and wait for the fix :)
Thanks for replying, yeah that sucks, I already submitted it https://www.reallusion.com/FeedBackTracker/Issue/MergeUV-to-UE4-normal-map-issue
Until then I'm just gonna try to learn how to merge the materials in blender.
You may want to search for some add-ons for Blender (not sure how precise they might be). I do not need it that often and it's usually something simple which I do manually in Blender and Photoshop. This body merge was fairly easy, the rest can be stuck up in between. But then additional things like cloth/hair would make it more complicated for manual merge.
That's nice, I only need to merge the body skins like you have in your image so I think I'll manage xD, many thanks.
